Hello fellow boost addicts !!
Just a little update / upgrade. Going with another GT40 !
My new build started a few months ago and I have been super busy trying to get everything close to perfect and fix any dislikes
from the last build as possible.
My project consisted of removing my:
GT35/40r T4
3 inch AA Race Exhaust
4 inch intake
3 inch hot side charge pipe,
50lb injectors & Tune
Walbro 255hp fuel pump.
The new parts consisted of:
GT40/94R T4
New AA Tune /60 lb Injectors
Walbro 400 pump
4 inch intake (New)
2 1/2 inch hot side charge pipe (New)
3 inch cold side pipe with by pass valve (Reworked)
4 inch exhaust / 4 inch magnaflow muffler (New)
Background on the Motor / parts
ICS Built OBD1 3.2 stock internals (8k boosted miles)
MLS Gasket /ARP 2000 Studs
Ceramic coated Boost Logic T4 manifold
AA bypass valve
Tial 44 wastegate
The exhaust is currently getting Ceramic coated and when it gets back I will have more pictures .
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
More pictures..
Stock motor
build thread:
Im assuming you had the GT4088 and are going to the 4094? Alas always on a quest for more power. In for the results. I see your using good parts and a good tune. Good luck with your build.
Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
You will go through days of joy and days of sadness as the pursuit for power leads to madness...
Stock motor
build thread:
Why are you going from a 3" hot pipe to a 2.5" hot pipe?
Sent from my GTX3582R
Well now, someone isn't playing around.
Subscribed, even tho I plan on putting you in my rear view ; )
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Looks sicks
How much did the materials for the exhaust run you and where do you buy?
I don't quite understand why you'd run a smaller exhaust. Care to elaborate?
He's not.
Nice upgrades Greg. I've heard some good reviews about your stuff.
Faster spool.
Thanks Chris
Under 500 and thats including the vbands
Im going from 3 in to 4 inch.
Thanks Craig, Im sure you have all the inside info.
Stock motor
build thread:
More Photos.
Stock motor
build thread:
+1
Stock motor
build thread:
I think its safe to say Greg has not 1 but 2 of the nicest cars on the boards.
I've had the privilege to be in both of them ; )
That is until Phil and I swim across the moat, past the sharks, and break into the fortress. We will let you know which one is faster
1996 332IS
Built 3.2
Looking good! I hope to see your car in person in the near future.
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
1996 332IS
Built 3.2
OLD
E30
636whp
NEW BUILD
335d
520whp
635wtq
OLD
E30
636whp
NEW BUILD
335d
520whp
635wtq
Nice!
is Karl doing your tune?
ever think about cutting your bumper to show/improve airflow to your IC?
1996 332IS
Built 3.2
did he buy a new bumper, is this same M that use to have the bumper cut? If so, thats where I got the idea. Wheres the link?
1996 332IS
Built 3.2
It is subtle.
